It is currently February 22, 2024, 1:37 pm
 Post subject: Aluminum Dash Treatment
PostPosted: December 17, 2023, 8:06 am
Just came across this short. Pretty cool trick, could use a bigger dowel for a larger effect.
https://www.youtube.com/shorts/Nd5B2B3vNgw
Logan
PostPosted: December 17, 2023, 11:17 am
Yes, that's a nice technique. I couldn't quite understand what he said though.
I know he said "a piece of wooden dowel with a ???? glued on, then use your valve grinding paste . . ."
What was it he glued onto the end of the dowel?
PostPosted: December 17, 2023, 11:39 am
I think he said "a bit of cork glued on to it" Russ
PostPosted: December 17, 2023, 6:00 pm
@trialsmangasgas
Thanks, Russ.
Merry Christmas to you.
Lonnie
PostPosted: December 17, 2023, 10:19 pm
And to you and all the rest of the Locosters. Russ
PostPosted: December 20, 2023, 12:35 pm
Merry Christmas to everybody.
Tibor
Tibor
'20 Alfa Romeo Stelvio daily
Locost/442E in progress
PostPosted: December 20, 2023, 6:05 pm
MERRY CHRISTMAS TO ALL OF Y’all !!!
Skidzzz
japanese proverb - If you fall down seven times.............stand up eight.
PostPosted: December 21, 2023, 4:04 pm
Thought I’d share a recent project. I really like the engine turned aluminum but even the abrasive stick was beyond my budget. Went with an overlay - about $25 ish. Not a wrap but an adhesive overlay. I’m happy with the results!
Merry Christmas to everyone!
-Robert
PostPosted: December 21, 2023, 9:09 pm
I went with boring old black wrinkle finish. To me, the less distractions the better, which includes bright/shiny/reflective surfaces. I don't like the faux chrome present in many cars for the same reason.
PostPosted: December 21, 2023, 9:38 pm
Carbon Fiber overlay, to hide the scratches.
Honey anyone?
PostPosted: December 22, 2023, 12:35 pm
I ended up applying a walnut burlwood veneer to a steel dash panel. Then finished it with several coats of Minwax clear.
I found a Saab walnut knob to match with the same shift pattern of the MGB trans and have since covered the tunnel top panel with black marine grade vinyl to match the speedster style seats.
I am thinking of covering the tunnel sides and rear bulkhead with the vinyl as well. Then install outer panels against the body in black vinyl as well.
Thom
