Like i said earlier today.. it would be faster to do it the way i said to get it out.. with so much flat area an orbital sander will make it go quick...
These are those wheels i was telling you about i had..
These are pictures of them when i got them.. they were scratched and and had curb marks....
This is what it looked like about an hour later..
How i did it was the following,
-Sand paper, 320,600,1000,1500,2000
Wet and Dry Versions-a bucket of HOT water with dawn power scrub (Never sand aluminum dry.. the material you sand off.. just scratchs it worse...) You constantly dip the sand paper to get the material off and spray the surface to get the sanded material off the surface... when i did the final sanding with the 2000 grit i layed the hose where it drips on the surface while i did it because the slightest material will rescratch the surface..
-mothers mag polish (only do this step after all scratches are gone.. cause all it does is make it reflective..
-Wax, I like using 3m cleaner wax cause it seemed to make it last the longest.. both mothers aluminum wax and some other brand i tried last very little time before scratches came back..
