Backing up a bit now to the electrical system. I have done multiple "wire diets" before and while not difficult, it does take a lot of patience. I found the wiring diagrams on line - these diagrams show basically connector to connector versus wire by wire like a true schematic. After pulling the harness from the donor:
And after several days of cutting, snipping and re-soldering:
For safety, I wanted to make sure I had a built-in safety for the clutch. Initially, I installed a pressure switch after the clutch master cylinder, but wanting a more positive disconnect, I incorporated the OEM clutch safety switch into the firewall. Not the prettiest installation, but it works:
My original plan was for six gauges (speedo, tach, voltage, oil pressure, water temp and fuel):
However, I decided I wanted less clutter and opted for Speed Hut gauges that combine everything into two 4" gauges:
I also wanted to have a small center console to incorporate a charger, the ignition switch and a small phone cuddy:
I will cover the console similar to the dash eventually.
