Going to be lots of detail stuff for a while as I finish each piece. Fun but a different pace and thought process.
I got the hood and scuttle done and ready for paint. That meant building a prop rod (holy crap there are a lot of details on a car), some panel alignments, a little bondo and a lot of sanding. They'll sit now until spring when I can get enough ventilation to make a good paint booth without worrying about the heater airflow in the garage. I'd love to have them done-done but there's plenty to do before I need them painted.
I finished all the stand-offs for the gages and switches for the 'floating' dash panel. These were fun. Cosmetic machining with no real tolerances to speak of. I then clear powdercoated the machined pieces. Matches the gauge bezel finish nearly perfectly.
Today was a huge stupid victory! I have been counting on sandblasting and powdercoating the throttle bodies which means I need to replace all the sealed needle bearings. Given that plan I haven't been at all careful with dust or chips in there so they really do need to be replaced now regardless of paint finish or sandblasting. However, I didn't realize they were nearly impossible to get out! they only have a clearance hole for the throttle shaft, not the bearing OD so there's no way to get a punch on the back side. I ruined both of them on my one disposable test part and was onto trying the first one that actually needed to be used without any success on practice runs, yikes.
I whittled out a small(really small, 8mm), expandable puller for a slide hammer. It grabs the back side of the needle cage after I pull out the backside seal with a dental pick and hopefully pulls the bearing out by the outer face. Sucks being an hour into a tool thinking it was very likely to fail. Pretty happy with how well it worked given how impossible it seemed using more normal methods on the first part. I even tried drilling on that first one but the races are super hard, wasn't going to leave the aluminum in nice shape at all.
So, next up is sandblasting and powdercoating the TB's, pressing in new bearings, re-assembling, and storing them for later. Same with polishing the intakes and finishing the valve cover. Then header, then more body parts. Once it's a bare frame and everything is finished on a shelf we go in reverse order, I guess. This is pretty fun, not a ton of hard thinking.
Alex
