BostonWill wrote:
Miatav8,MstrASE,A&P,F wrote:
Not sure what the uca has to do with it.
I think your front rates are much too high and will not stay in the seats in droop but that is not uncommon.
Might look at this too:
viewtopic.php?f=5&t=11815&p=112797&hilit=motion#p112797meant to say LCA.
Thom
Many of your inputs don’t look right to me. Before calculating, you need to perform a mock up of the coilover to determine the motion ratio, mounting angle, droop, and necessary coilover travel. I don’t think you will be able to use the existing upper coilover mount. Mock up a “coilover” with threaded rod and 2.75 inch rigid washers (plastic, wood, foam, etc), then lower the LCA to where you want full droop. Put the lower pivot eye as close as practical to the LBJ, then tilt the upper pivot eye outboard as far as necessary to clear the UCA.
Have you completed anymore work on the LCAP framing? Last pic I saw was a year ago.
With 2 inches of droop, the rate at the LBJ should be about 0.65 x the corner weight for sport touring (i.e. semi-casual with cup holders). The actual spring rate will be higher due to motion ratio of the LCA and coilover mounting angle, since coilover compression is less than wheel travel.
Hypothetical: If the LCA ratio is 14/12 (0.86) and the coilover angle is 20 deg (0.94), if the corner weight is 325 then:
325 x 0.65 = 211.65 / 0.86 = 246.1 / 0.94 = 261 lb spring rate. At full droop, the spring will come off the seat less than a 1/2 inch. Should never be a problem unless you have a habit of jumping things (Thom, the estranged, red-headed step-child of the Duke family?).
Ford IFS
