I went ahead and pulled the trigger on the TBI injector for the SU HIF carb conversion. After reading more on the MGEXP web site about everone's experience with EFI conversions on the MGB motor I determined that as long as I continued to use the stock rebuilt head, I would have performance issues. Bottom line, the log style intake manifold coupled with shared intake head ports you will always be limited with what performance you will get out of the motor. King of like Ford's old 6 cyl motor they installed in the Falcon and Mustang.
There are aftermarket heads for the MGB, they give you seperate runners for the intake and exhaust plus they are crossflow designs. Thos fixes the limited performance issues with the MGB motor. But very pricey- $!.5k complete. And then you need to disassemble it, clean up the casting on the runners, and combustion chambers and then cc the chambers, lastly, replace the valve guides with bronze inserts. That adds almost another grand to the cost of the head. At that point I should go a comlpetly different way for an entire motor.
And yes, I should have maybe chosen a diferent drivetrain all together. But I'm down the rabbit's hole this far and I decided to set a limit to costs on the motor but finish it with drivability in mind. Even with all of these limits I am reminded that the original Lotus & started with a 950 cc Austin Healey Sprite motor and with its light weight and great handling it upset the world of motorsport.
So the TBI adaptors arrived along with the other many boxes I orderd to move the build forward. The machining of the units was very good! They fit like they were factory! The injectors are angled of course towards the back of the throttle plate. The GM (94 Saturn 1.9L) TBI injectors pop right in.
The injectors are not installed yet nor is the linkage between the carbs. I am searching for the linkage bar. Afraid my friend who gave me the motor misplaced the inkage parts. But a member of the MGEXP site says he has what I need and he is only about 30 miles away. Lucky score!
I orderd the TPS which is an easy design using a GM sensor mounted to a lazer cut mount that uses the barb base mount bolts
I ordered the recommended Accel fuel pressure regulator. I mounted it to the heat shield, this spot clears the exhaust manifold and will be easy to plumb and adjust. Nice piece. Waiting for the Pressure guage. Now to plump the fuel lines.
I also ordered a new oil cooler. It will sit just behing the radiator. I planned on adding an alum sheet just under the area of the frame here in front of the oil cooler. Now I am thinking about making it a small scoop with a wire grate (to block rocks) to route air to it and still control air flow after the rad.
The Rad sits on the bottom two pieces of angle iron with two built in pins on the bottom of the rad which also has rubber pads to allow some movement and has two bolts at the top two verticle pieces to secure it to the frame. Of course this places the rad cap under the nose so I will have a inline remote purge/fill cap in the upper line. But with the Harrison (Corvette style) tank at the firewall I can easily monitor the coolant level.
The MGB heater valve bolts to the back left side of the head.
My valve was shot- completly corroded. The base of the valve is cast of aluminum.
So I cut the mounting flange off of my old MGB valve and will drill out the hole for the water flow and add a nipple for a 1/2" hose. Interesting that the hole in the block is about 3/4" and the hole thru the valve is only about 3/8". Yet the valve gets a 1/2"ID hose for water flow.
But the Caterham 7 heater I got on ebay has a really nice valve installed on it.
The valve has a bypass design to it. Closed- all flow bypasses. Open- it is diverted thru the heater rad. So when I do not need heat but would like some fresh air flow under the dash to the foot area it will allow cool air to flow thru the heater and I can even turn on the fan to increase the air flow w/o heating the air. Nice in the summer!
Thom
