KB58 wrote:
Good for you on putting the turbos outboard, though I realize that just sort of happened by itself due to the exhaust manifolds. Putting them out there moves a whole lot of heat out of the engine compartment, frees up space, aids turbo cooling, shortens the downstream exhaust, and puts them on display.
If it was my project, I'd leave out the intercooler and just go low boost of 7 psi or less. Higher power than that will just make expensive smoke, and not necessarily all of that being tire smoke.
Going without an intercooler is probably a good idea to start with. Is not like the engine will be particularly stressed and its got a standalone ecu to adjust timing accordingly with iat.(rather then running a stock ecu and praying to stay out of knock)
The engine turbos were put there because I had a spare engine and a bunch of spare turbos, its sort of the optimal setup for a front sump 1uz modifying stock manifolds. The chassis has been built around the motor, the side rails are 12" high in order to clear the exhaust and the wheelbase was determined by how far the front tires needed to be to not rub the turbos at full lock. Its a bit silly, as mounting the turbos further back would've reduced wheelbase and helped COG but this first car is about learning things the hard way.
The idea is to for-go a traditional lotus body and build something with a hardtop and closed wheel. Learning to draw in inkscape has been a struggle so bare with me on the sketchs.
The body is a separate project once the chassis is fully driveable.
