It is currently April 16, 2024, 2:48 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 Post subject: Re: GBS Zero Build
PostPosted: May 24, 2021, 3:39 pm
RoyzMG wrote:
I'm a little confused. Is that really a Miata rear differential. I'm used to seeing the large "bat wing" ears at the top of the differential.
Roy
From his pics it looks like they cut off the outer part of the wings and bolted through the upper part of the center section.
Bill J
442 Locost - in progress
'12 GTI - Daily
PostPosted: May 24, 2021, 5:13 pm
Rennkafer wrote:
Roy
You are correct, this allows GBS to use the same Chassis Jig for both the Ford based model and Miata, all they have to do is change up the mounts. the aluminum on the Miata Diff is fairly easy to cut, took a hole 10 min to do, if that.
PostPosted: May 25, 2021, 10:30 am
Great photos. I'm very impressed with the quality of the chassis/suspension setup and components.
PostPosted: February 27, 2022, 6:05 pm
Looks like gbs offsets the miata differential to center up the pinion flange in the trans tunnel. I was not aware that this would be ok with the miata tri-pot. Good to know.
PostPosted: June 4, 2023, 11:12 pm
I know I'm a bit late to the party, but am currently hunting around for examples of builds of the GBS Zero Mazda and MK Sportscars Indy RX-5. Any updates on the build? Did you ever consider the Indy RX-5? Lastly, it looks like there is no build manual for the GBS Zero Mazda. Is that true?
Thanks!
PostPosted: November 28, 2023, 8:27 pm
Interesting. Wonder if an NC diff would also bolt up? But then how to get driveshafts from NC diff to NB hub/upright?
Feedback from GBS is no, an NC diff doesn’t fit. Something about an awkward shape. That’s why they stick with NB and Sierra diff options.
Users browsing this forum: jinca and 10 guests
