This post will be a smattering of things. I'm going back through my notes and schedule getting familiar and confident with the data I developed before my multi-month layoff from the Locost project. I looked at my lower ball joint notes, and felt they were vague.
The lower ball joint assemblies have 5 components in all if you count the Zerk fitting, but it comes apart easily for measurement, which is what I wanted to verify by doing again, and improving my notes.
I did make some drawings of the bent plate for the lower control arm. It occurred to be it would be a good piece for the local waterjet outfit to cut in 3/16" steel, and then I'd only have to bend it. I got a quote, and it was reasonable, but they couldn't get to it for 2-1/2 weeks. So, I'm going to do it by hand.
Fortunately, my HP printer/plotter is accurate enough to do a 1:1 drawing, glue it on to cardboard, and use it for a pattern. I just center punch the holes out using the pattern, then drill them out based on the center punches. That's why the holes are not cut out.
I'm going to try an interesting approach to the lower control arms. I could spend a lot of time building an accurate jig, but I think I can build them in place. I have some very accurate wooden bases that hold the spindles at the correct ride height even without the tires mounted. The ball joints disassemble for easy viewing and placement (me thinks) of the ball joint center locations at the correct distances in X,Y and Z. The critical measurements are placement the ball joint center locations and the length of the control arm from chassis bushings to ball joint center location. I won't go into a lot of detail, but I think I can do it in place.
I like to noodle around with stuff and put things in place to try them out. I found the rear, upper suspensions bushings were rubbing on the bracket. They are the two shallowest of the 8 brackets. With the bolt in and tightened, the bushing collar made pretty tight contact with the bracket and was tough to rotate.
So, I put the bushings in the lathe, and turned down the bushing collars about 0.040 and they fit much better, and turn readily when the 1/2" bolt is tightened.
The fit is pretty decent now. The other 6 brackets do not have this issue.
So, that's it for now. I need to go out and find some hole saws to drill the 2-1/2" hole for the weld-in ball joint ring, then trace out, fab and bend the LCA bent plate. Tomorrow's a half day, though. It's Super Bowl time tomorrow afternoon. Go Rams!
