This just in! A spy photo from deep within my state-of-the-art build lab.
Fit the rails to the chassis and marked off to start fitting the diff and install lcaps on the bench, then finish in the shell before welding to the chassis. Still need to rework the rails around the T5 tail housing and mount the trans mount brkt. BFH on standby.
Difference between 7.5 front diff mounts and 8.8 with bonded washers and a inner crush sleeve. I cut some 0.75x2.5 1/4 wall dom to reuse the original tbird bolts but changed my mind.
The triangle cuts are to clear the original nut plates welded inside the frame that are in perfect shape and I didn't feel like trying grind out from the inside. The rail outer wall falls right on the hole cl.
Have most of the front mount done too with three 1/8 strips but I think I've done enough for today. The sun is blazing.
Some unusual builds I've seen on FB or craigs. Yes, I am being nice. To each his own. The beholder and all that....
Ford IFS
