trialsmangasgas wrote:
Chuck, that 8th shingle from the right 12th row up is crooked!!!! Other than that great job. Russ
It is good that you can't see the other side then. Life is imperfect, just like my shed.
Miatav8,MstrASE,A&P,F wrote:
Nice job! I’d jack it to add a full 8 inch standard block to the height and lay 6mil plastic sheet to reduce condensation collecting on the bottom of the floor from ground moisture. Probably trench the side sloping toward the shed to prevent water from ever flowing underneath down the hill.
Trade offs, trade offs. I have landscape fabric under the shed that will allow collected water to percolate down rather than hold puddles of water. The skids, floor joists, 3/4" ply floor and the bottom wall plate are of treated wood. I chose to elevate the shed slightly to allow ventilation underneath too. I might have to do something to keep animals from homesteading there. The ground under the left forward pad is about 6+ inches higher than between the right center and rear pads. Any water that happens to "flow" under the shed should flow right out.
horchoha wrote:
Good on you Chuck, building my cistern/pumphouse this spring I know exactly what you're talking about (and how you feel at night).
Votaren is my friend and the pillows will absorb tears of pain
I followed your cistern/pumphouse build. Very nice! I was pleasantly surprised at how relatively good I actually felt after each day. I was expecting a lot more pain. I did run out of steam and my brain was not functioning right the day of my post. Yesterday I took the day off and seem to be thinking more clearly. My right (hammer) hand appears to be slightly swollen and has my normal finger stiffness. I have never heard of Voltarin. I'll have to check that out. Tough getting older but sure beats the alternative.
