Finally, something to show. I fully welded the firewall mods and ground down those welds. Up to now they were just tack welded in place. I made a small change in the area of the steering shaft, radius-ing a cutout. This is where a flat panel matches up with a cone shaped recess. This provides clearance for access to the header fasteners. The original engine swap kit required removing the engine/trans combo to get to the header. The header was intended to be installed before engine is placed into the car. Dumb plan for future service, if required IMO.
Then started the final design of the floor clearance for the trans pan. Pics to follow when that is completed.
On a different front, I received the first part of my DIY cable to communicate the scan9495 program to the PCM. THe USB to Rs232 (5V ttl level communications) How can you pass up $0.99 on eBay including shipping from China. I bought 3.
Still waiting for the OBD2 connector to finish up to cable. For SAG, I attempted to try it out. The adapter requires a mini USB cable that I grabbed from my stash. Win10 loaded the driver and it shows up on Device Manager as COM6. The Scan9495 program appears to recognize the adapter. The transmit LED flashes a couple of times when I try to "connect" to an imaginary PCM, not connected yet. From what I can tell, this device uses a cloned FTDI chip. Frankly I don't care if it original or not so long as it works the few times it will be used.
