The wiring harness is back in and the car starts and runs pretty well. At first it had very rough idle and I spend a lot of time diagnosing it. But suddenly it cured itself, something sticking must have gotten unstuck. No trouble codes thrown by ECU. Today it ran round the block with no problems.
So now for the body. I decided to use a skin-on-frame approach, very similar to the way kayaks are made. Some folks are 3-D printing the frames for kayaks as well. For car examples, see the BMW GINA,
https://www.youtube.com/watch?v=Blqn0Om ... CarsGarage and the EGAD Light Cocoon,
https://www.youtube.com/watch?v=Tmw8dxP ... =EDAGGroup.
I don’t have a design yet, but I made a test panel to experiment with (see photo). It took only four prints on a Creality CR10S 3D printer to make this panel, that is, it’s made of four prints that are then plastic welded together. Each quarter took 12 hours to print. As you can see from the photo, the test print is almost big enough to be the hood (but I will not try to reuse it). Next, I will cover this panel with polyester cloth, heat shrink the cloth, and spray it with several coats of polyurethane. If I need more strength, I can add a layer of fiberglass on the back side.
The final body should be much lighter then if it were made with solid panels that were 3D printed and covered with fiberglass. It will also be cheaper to make and could be illuminated from the inside for some cool effects (see the Light Cocoon video above).
[img]test%20panel.JPG[/img]
