It is currently December 1, 2021, 3:09 am
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: July 12, 2021, 7:47 pm
Allow me to translate that into 5x5-1/2 adapters with integral concentric rings/locators for the 32 ford rims.
I guess you have three wheels? The fourth fills the barrel back.
What the heck is a udrill hub? What's wrong with drilled hubs? :shock: :cheers:
My posts are my own opinion and do not represent an official public position by any other person, place, thing, animal, vegetable, mineral, etc.
https://www.azsenaterepublicans.com/audit
https://www.oann.com/india-govt-declares-most-populated-state-officially-covid-free-after-widespread-use-of-ivermectin/
https://www.oann.com/fauci-hhs-officials-discuss-using-new-virus-from-china-to-enforce-universal-vaccines-in-footage-from-oct-2019/
https://www.oann.com/the-story-of-iverm ... -the-drug/
https://pubmed.ncbi.nlm.nih.gov/33278625/
https://rumble.com/vokrf7-sen.-johnson-expert-panel-on-federal-vaccine-mandates.html
PostPosted: July 12, 2021, 8:23 pm
For those readers who are not aware of a "Udrill Hubs/rotors" here is a picture of my Mustang II Udrill hubs/rotors that are spot drilled with all the possible locations for various lug patterns. I chose to go this route to ensure having the option of 5 holes on a 5-1/2" pitch circle.
PostPosted: July 13, 2021, 8:01 am
Wow. I was wrong all the way around on this one! HA!
It appears the original drums are not flat so the support provides a raised center to clamp against instead of a concentric ring. Obviously a spacer and not an adapter if you drill 5.5 through I’d avoid spacing any more than needed to minimize scrub.
Where did you get the rotors? I recall seeing them in street rod magazines years ago.
A primer for us regular folk:
https://www.speedwaymotors.com/the-tool ... 1935/28813
PostPosted: July 13, 2021, 1:52 pm
Link to my separate thread requesting assistance with upper ball joint for Mustang II spindle.
viewtopic.php?f=5&t=20963&p=263086#p263086
PostPosted: July 23, 2021, 7:49 pm
Decided to part out the second donor bike to clear workshop space. This bike had crash bars that bolted under the engine to the original center stand mounts so I needed some lift.
Considered buying an engine crane but used my Little Giant ladder and a come-a-long, worked fine.
PostPosted: July 24, 2021, 12:43 am
Considered buying an engine crane but used my Little Giant ladder and a come-a-long as a gantry crane, worked fine.
There I fixed that for ya :cheers:
Perry's 5th Build, the Super Slant Six 7
PostPosted: August 26, 2021, 5:11 pm
Test post
PostPosted: August 26, 2021, 5:18 pm
Prepped an engine for use in building mounts.
PostPosted: August 26, 2021, 5:32 pm
Bent some metal today.
See Spikes method here............https://www.youtube.com/watch?v=lAndclVcX2E
PostPosted: August 30, 2021, 3:37 pm
Motor cleaned up nice, and frame is coming along.....:D
Spike
PostPosted: September 2, 2021, 8:45 pm
Nearly ready to weld the upper frame.
PostPosted: October 27, 2021, 5:32 pm
Been a bit lazy what with changing Tig Torch and hose for a smaller size, obtaining a Metric gas fitting for my Welder and changing jobs has seen a slow down in activity. Should be back up soon.
PostPosted: October 27, 2021, 5:40 pm
Did get the valve covers polished. Down pipes are Jet Hot coated. All bolts are hex head stainless.
cron
