Well just over a week ago I put the glass body on the frame then put that on dolly's and put the Gazelle away for the winter because we're going south in less than 3 weeks.
That was a mistake, I found myself walking around the shop in circles itching and scratching with nothing to do, so I rolled the Gazelle out and am doing some small items on it.
Glass patched some holes in the pan then sanded it. Sanded and primed the trans tunnel I fabricated. Shortened the shifter so the knuckles don't hit the dash.
I found that I'm too big for the car in that my knees will hit the dash when sitting in the car, not good. Wifey fits perfectly, she's 5'4".
So I cut the 2x2 cross member behind the seats at an angle and capped it. This will allow me to set the seats back another 2". Also extended the seat base another 2 1/2" to reposition the buckets further back.
I took the buckets to my upholstery guy to get done over the winter.
Then I started work on the dash. Made a cardboard template, transferred to plywood and cut it out.
Mapped out gauge placement. Had to keep gauges 1 1/4" for the top of the dash because there is a padded roll that mounts across the top. It will be a simple dash, GPS speedo that has turn indicators and high beam indicator built into it. Then oil press, coolant temp, volt, and gas gauges. Headlight and wiper switches are on the steering column. A couple of 12v power points.
Some pics.
