Auto-X Fil wrote:
Both books are in the mail. I've read pretty much every thread on the site regarding Miata donors already, so I've got a good idea of what's been done - but the build pages I found left out details about what they started with.
chetcpo, I've been following your build. It looks nice, but is a bit more than I want to do right now. Are the upper spring mounts and associated tubes all to book spec, or did you relocate them according to Miata dimentions?
When you say I need to lengthen the wheelbase to fit the subframe, is that because the front of the subframe is so far ahead of the axle centerline? Mark Rivera's build looks to keep the axle pretty far forward, no?http://rivera.fotomojo.us/a/MX7/100_2145.sized.jpg
Well actually not so much. His wheelbase is 7.5" longer than Kieth's CMC chassis according to
the C&D article. Granted he used a +442 chassis, so four of those inches don't count. The problem is that the cockpit area of the seven is so low that the bottom of it actually sits below the diff and lower control arm. This makes it so the only way to get the factory rear subframe and control arms to fit is either to move the cockpit area of the car up about 5" (rediculous) or move the subframe back behind it, increasing the wheelbase by about 4".
I don't think it is any huge handicap to have the longer wheelbase, but I'll bet you'd notice the difference if you slalomed them both at an autocross. Mark's build also came out over 200 lbs heavier than Kieth's, but it's likely most of that was the FI bits.
As for the spring and suspension hookup locations you ask about in my build they haven't been established yet, but no they won't be in exactly the same place as the book plans. Once I get it sorted out I would be happy to share what I did with anyone who wants to know. If you aren't comfortable blazing your own trail you might want to just buy a Coveland Miata chassis and Control arms and be done with it. That way you would at least know that you were getting a tried and true product. Truth be known it isn't that much more expensive. (I'd estimate about $1800 more)
