At the 'element' level the tube doesn't know that it is bent - think free-body diagram. But the bent tubes will be carrying moments that straight ones don't experience. So as Jack points out, the design becomes buckling-constrained rather than seeing just the simple tension/compression loads of a conventional space frame. How to assess buckling risk is the challenge.
Going to bigger diameter tubes offers reduced risk of buckling, but defining critical loads may still be a challenge. As an alternative to increased tube diameters you could reduce span, but you might end up with a birdcage .... Bigger tubes are probably the more practical approach, as long as you can calculate critical loads, and of course, make a rational estimate of what the design loads are (frontal collision maybe?), I wonder how may bent-tube exo-cars have been through that process?
But I do like the looks.
Warren
Build Log:
viewtopic.php?f=35&t=11601
