It is currently July 26, 2021, 11:38 am
 Post subject: Frame question
PostPosted: April 22, 2021, 11:26 pm
I ended up buying this and am too wide in the shoulders to drive it! My question is can I cut those horizontal bars out and relocate them lower? Thanks Rich
Locost-Turbo 280HP
SOLD: Locost CBR1000 powered autocrosser
SOLD: Locost R1 powered
 Post subject: Re: Frame question
PostPosted: April 23, 2021, 7:57 am
That may not be the best way to tackle the problem. How about a pic with you in it with helmet?
You should also consider arm clearance. May be better to cut the lateral tube behind the seat then use a bod jack to spread the hoop, then weld in a new lateral.
PostPosted: April 23, 2021, 9:06 am
Depending on your seated position with a helmet on, I'd consider moving them up instead of down. Or like MV8 mentioned, widen the main hoop if you have plenty of room to pass the broomstick test.
PostPosted: April 23, 2021, 12:06 pm
Not sure those upper bars are structural, there is a node at the front of the bar but none at the rear.
I'd do a torsional analysis before moving forward.
You may be able to fix this problem and increase rigidity (improve the chassis) at the same time.
PostPosted: April 23, 2021, 1:42 pm
I'm trying to recall the intricacies of FSAE frame design, but those look to (hopefully) be loaded primarily in torsion. If that's the case, they could likely be moved up or down. As noted though, make sure you have enough elbow room for sawing the wheel if moving down.
I want to say a fairly common alternative designs is to run them from high on the front hoop and triangulated it down to the node on the main hoop. Judging by the bulge in the bodywork, I'm guessing that might also just end up moving the interference point down though.
Perhaps replace with kinked (hockey stick shaped) shoulder tubes that provide better shoulder/elbow clearance? If not too concerned about weight, you could then even triangulate fore and aft to/from the kink. Bodywork would need to be modified too though.
PostPosted: April 23, 2021, 2:54 pm
Rich,
there is a plethora of improvements that could be made to this. Are you interested or is this another short term foster care?
PostPosted: April 23, 2021, 3:11 pm
Those aren't doing much for stiffness. As Bent Wrench said, there is nothing supporting them in the rear. The diagonal that should be below that bar is really needed to make it effective. Otherwise it is just a rectangle that is able to become a parallelogram under load.
Users browsing this forum: Google [Bot] and 7 guests
