Yes I would like to elaborate, let me start by showing the picture of my trunk area. I built my chassis to book specs.
My panhard bar is as close as I care to have it to the axle as it sits. Between tube Y and V is the max area that the gas tank can sit. There are alot more commercially available fuel cells available if I add 4 inches to the rear end. I also plan to make a trunk storage area above the gas tank and the axle. Also to get my rear out of the car I have to remove the a drum brake to get past 2 round tubes going from y up to the 4"square plates. I could have just put my fuel cell above the axle like CMC did, but that would create dead space behind the axle, and raise the CG, and I would loose any chance of storage space. I also still have to add more to my roll bar (2 supports toing to the side plates and an X brace between them).
I've been working on a gas tank (I have it made out of cardboard so far, just need to fabricate the metal tank now). to fit the space.
