It is currently May 15, 2024, 2:43 am
 Post subject: Miata differential cover
PostPosted: March 7, 2022, 10:06 am
Most of us using the vodou and saturn plans as reference for frame building are familiar with the changes to the rear suspension, to accomodate the batwing/moustache bar rear cover of the miata differential, specifically the 7" 1.8 variety. Well i have a solution that gets rid of that nonsense and allows you to build the rear diff cage per haynes book.
There used to be a guy in the uk making covers that replaced the miata cover with one he fabbed up that had a square bolt pattern on it to mount to a book diff cage with some mounting ears. His name is phil eagle and he ran talon motorsports. He no longer does sny locost related work. I have an alternate sution, tho.
The s2000 diff case fits perfectly on the miata diff. It also gives you 4 convenient holes for mounting it solid to the frame.
The next post will have photos, as my phone isnt cooperating with the photo uploader on here
PostPosted: March 7, 2022, 10:07 am
https://imgur.com/gallery/3Dl0tQe
PostPosted: March 7, 2022, 10:09 am
Heres what talon did for the front diff mount. Basically bolts to where the sierra diff mount on the pass side went
PostPosted: March 7, 2022, 5:45 pm
And the 1.8 Miata axles work with this cover? What about axle seals?
Build on
Chris
PostPosted: March 7, 2022, 6:03 pm
Seals appear to be the same, guy who does these in florida says they are the same.
