It is currently May 14, 2024, 8:58 pm
PostPosted: November 6, 2023, 9:41 am
Hi everyone!
I´m building a Miata based Locost and am in the beginning of building the rear suspension ..
I´m wondering if the Miata rear uprights can swap sides, without any negative consequences?
Since the top A-arm mount is shifted to the front it would be beneficical to packaging if I could move the offset to the rear instead ...
The space could then be used for the shocks ..
Any input is highly valued!
How they should go;
How I want to use them;
And a general overview;
PostPosted: November 6, 2023, 10:18 am
I did that with Midlana for two reasons. It shifts the upper pick-up point, done for the same reason as you. It also points the E-brake cables toward the rear so they have a bigger bend radius to head forward. No problem.
PostPosted: November 6, 2023, 11:02 am
I think I would be concerned with brake torque jacking on the rear suspension?
PostPosted: November 6, 2023, 12:34 pm
It's been done many times. There is no change to jacking or anti-squat since the irs virtual swing arm (VSA) doesn't change. It would be a factor if it were ball joints top and bottom to where the axle made an arc with suspension travel in the side view.
PostPosted: November 6, 2023, 9:14 pm
Recommend for all of the above reasons. Caught me at a perfect time as the rear fenders are off for winter repairs.
My build http://www.locostusa.com/forums/viewtopic.php?f=35&t=7370
PostPosted: November 7, 2023, 3:43 am
That was easier than I imagined! :)
Perhaps my google-fu is going bad, I couldn't find any info on the topic, strange when ther's cars driving around built that way.. :oops:
Thanks everyone!
PostPosted: November 7, 2023, 3:48 am
Your build was a real inspiration when I started my own, so thanks for that! Strange that I never noticed you flipped sides on the uprights.... :oops:
I see that you've put some miles down, have you had any problems with the rear diff mounting? I've gotten the impression that mixing hard and soft mounts can be a bad thing, and solid mounting the front while keeping the stock Miata upper bushings should really test that theory to the extreme.. :D
PostPosted: November 7, 2023, 6:25 am
Westfields come that way (time warp to 2007 posts).
viewtopic.php?f=5&t=1770
PostPosted: November 8, 2023, 6:44 pm
I am another that swapped uprights in the rear. No issues yet.
Build on
Chris
PostPosted: November 8, 2023, 9:58 pm
Thanks for the compliment. Got lots of pics and happy to share.
For the diff I've had zero issues with the mounting design from a structural standpoint. It's been rock solid. The things that I have corrected since the original build is making enough room to mount a 1.8 Torsen diff, ensuring the mounting angle of the diff is 100% parallel with the transmission output, and providing a little more clearance for installation/removal.
I'll see if can update one of my posts to tell the story. Lots of lessons learned to share on that one.
PostPosted: November 8, 2023, 9:59 pm
PostPosted: November 9, 2023, 4:05 am
I´m going 2002 1,8 Torsen (but started with a 1.6, which can be seen in the pics above, not much clearance to the front), and Bofi Racing poly bushings for the top .. I´ll probably go solid mount in the front, the worst that can happen is a cracked third member, which sounds unlikely .. If you haven´t had any problems with the weak 1,6 diff I guess a welded 1,8 should remain intact ... :)
Would love to see an update of your build thread!
One thing that has bothered my some over the years is the chart of miata uprights measurements and a-arm attachement points you posted in a excel screen shot a while back .. I tried to convert to metric (because living in Europe) and plot them in sketchup, but I couldnt get them to really match up .. I think there is something off with the rear part of the chart ..
PostPosted: November 28, 2023, 7:18 am
Hi. I have a similar problem. How did you convert? and how many numbers after dot did you use? did you try online converters like https://oneconvert.com/?
