It is currently April 18, 2024, 4:07 pm
PostPosted: December 6, 2020, 9:24 am
1992 Westfield SEI (LOTUS 7) - SOLD
1992 Westfield SEI
condition: good
cylinders: 4 cylinders
drive: rwd
fuel: gas
odometer: 5500
paint color: red
title status: clean
transmission: manual
type: convertible
1992 Westfield SEI (IRS with Limited Slip)
Comes with full wet weather gear. Top and Side Doors
Just added a Brooklands windscreen
New Spax shocks and springs, Rear, new QA1's front.
Engine is a 1600 Crossflow (711 M) bored out to 1680, Performance Ignition System from Lumenition converts contact breaker ignition system, to up to date electronic ignition, bottom end has been fully lightend and balanced including clutch and flywheel, Con rods shot peened and balanced end to end, racing clutch, stage 3 head, high performance oil pump, Kent camshaft, duplex timing gear with vernier adjustment. Large capacity oil sump. Stage 3 head unleaded conversion, polished ports, Paul Ivey ring flow valves, piston crown modified for anti deterioration, competition valve springs, caterham 7 inlet manifold matched and flowed to cylinder head. Twin DCOE' 40 carbs, 244 Kent road/rally Cam 3000 - 7000 rpm power.
4 Spd Type E gearbox
Body has some marks, nothing major, would rate it 8 out of 10, Rear frame has some surface rust, and some on the rear half shafts. Overall car shows very well.
Has heater and defrost, heater box in cockpit, Locking Glove box and Map Light.
New GPS SPEEDO, and LED front lights, CYCLE wings.
Max HP estimated 135 - 140 Bhp at 7000 rpm.
Call George 954-575-2111
PostPosted: May 24, 2021, 7:34 am
NEW PRICE
PostPosted: May 25, 2021, 10:15 am
geoz3 wrote:
NEW PRICE
Which is what?
PostPosted: May 25, 2021, 10:45 am
I read 14.5 but that may be the "old" price.
Maybe its new and improved @ 15.5
Or does this default to COVID pricing, How many sheets of plywood is that going to cost me?
Honey anyone?
PostPosted: May 26, 2021, 6:52 am
I had it listed at 15.5 reduced it to 14.5
George
PostPosted: November 30, 2021, 11:36 am
SOLD
