This came from a Ford Ranger. I'm not using it because it doesn't have the bosses to attach the coils in a coil over plug installation.
The Ranger had a higher hood than the cars that used the engine and the spark ignitor mounted on the top of the engine instead of at the back of the cylinder head, so you will probably want to remove the mounting bosses. They will need to be cut off, and to look good the bases of the bosses will need to be filed to fair with the cam cover top surface.
I'm asking for $50 plus shipping cost.
I do not know how to add a photograph to the post.
Jerry Henneman
Jack of many trades
Master of unfinished projects
build blog/log at
https://jerryslocost.wordpress.com
