kabuku6 wrote:
You do have a good point there. I wish my schedule had a little more flexibility. As of right now I wouldn't be able to get up there until mid-late May. If Tom doesn't have any takers I may have to make that work.
Kabuku6, the tabletop is still here and unless someone beats you to, it will be until late June. Then I’ll have to toss it. The price is still FREE.
Some more details on the tabletop: The steel 2”x4” studs shown in the picture above are glued and screwed between a 4’ x 8’ sheet of ½” plywood on the bottom and a sheet of ¾” MDF on the top. The MDF was subsequently overlaid with a sheet of ¾” MDO (7 layer plywood with a resin impregnated fiber surface.) The MDO was screwed, not glued, to the MDF and shimmed to create a “dead-flat” reference work surface. The MDO is currently not detached and bears light scarring from my build.
If I had any garage or wood shop wall space left, I’d cut the tabletop lengthwise and create two 2’ x 8’ work bench tops. But alas, I may have to cut it apart anyway so I can haul it away if there are no takers. The MDO would get donated to a Second Use organization as that stuff currently retails for $100+ per sheet.
Larry, thanks for the support and kind words. Locosters are always welcome to stop by.
