Working on my MGB-GT, I found the donor engine, a 95 Camaro V6, had a couple of connectors where the insulation of the wires was missing at their connectors. In order to fix, it would typically require disassembling the connector, removing the crimped pins, buying replacements, crimping and reassembling the connector. In the end, the wires would be a bit shorter. This would be more of a problem if there were multiple wires in the connector housing but only a few had missing insulation. I have in my collection of solutions, a bottle of GB liquid insulation. It is a thick liquid, almost between rubber cement and toothpaste, that gets brushed onto the bare wires and becomes an insulation when it dries. a few coats are recommended. it is rubber based and is good to 200 deg F. The finished product has some flexibility, acting like a stress relief.
It might be something you could use.
