That's good. I'd set the diff pinion cl at the same height as the trans output shaft cl if practical.
The diff output cls higher than the hub cls is a benefit, since the joints are strongest when the hub and diff output are at the same height. Full power with traction should squat the suspension. Not critical to have a higher diff output but a best practice imho. A short driveshaft's joints does not tolerate much misalignment.
For easier production based on vsusp, tweak to try and keep the same performance specs but reduce the fractions to one or two decimal places. The arms that align can be three decimals in vsusp, but actually built (-0.375" or so) short when fully assembled collapsed with adjustability to go either way from the vsusp dims.
Ford IFS
