It is currently April 19, 2024, 4:34 pm
PostPosted: September 26, 2021, 11:13 am
As the sage Barbie once said, "Math is hard!" Well, it is for me anyway.. I'd think this would be straightforward, but I'll ask anyway to be sure (I've screwed up several times in the past trying to predict final RPMs) :roll: ...
I'm trying to calculate what my 'new' 6th-gear RPMs will be on a few different sets of tires.. everything else (motor/trans/diff ratio) will stay the same, so it's only tire size swaps that I'm looking at for this exercise... Here's where I stand with my BEC today:
--Current setup has me at 7,000 RPMs at 70 mph on 21.54" diameter tires...
--So I'm trying to figure my new RPMs at 70 mph on 22.29" diameter tires(?)
--And just for grins, what if I run 19.89" diameter tires... what RPM at 70 then?
So this simply boils down to a percentage of change, yes? i.e., increase tire size by 4%, and then <decrease> RPMs by the same 4%?
Thanks guys-
--ccrunner
Dean
1963 Volvo P1800 Restomod
viewtopic.php?f=36&t=19397
PostPosted: September 26, 2021, 3:10 pm
Yes, it's just not quite 4%. Closer to 3.48%.
22.29"= 6764.4 rpm
19.89" = 7580 rpm
PostPosted: September 26, 2021, 5:02 pm
This is my go-to site for speed vs rpm calculations versus trying to do the math myself: http://www.apexgarage.com/tech/gear_ratios.shtml
PostPosted: September 26, 2021, 6:18 pm
Just what I needed, and as always, very helpful.. thanks guys :cheers:
--ccrunner
Dean
PostPosted: September 27, 2021, 12:47 pm
Keep in mind it's the rolling diameter that's important. It's doubly important on lightweight cars like Sevens because we run really low tire pressure. Because of that, the "diameter" of the tire will be about 1/2" smaller, and that's what should be used in the calculations. Measuring from the ground to the wheel center will be accurate.
PostPosted: September 27, 2021, 7:42 pm
I'm not sure how much the od would grow (to inflate the flat spot-radials don't grow) at speed with heat.
I've used the formulas at face value and the speeds have been spot-on when compared to gps in a straight line and those mobile radar speed warnings.
A non lockup automatic typically looses about 5 mph through a standard converter.
PostPosted: September 28, 2021, 12:45 pm
My go-to site is: http://www.grimmjeeper.com/gears.html
Also lets you play around with rear diffs and transmissions.
Logan
PostPosted: September 28, 2021, 5:24 pm
I wrote a program and posted it here some years back. You are welcome to use it as you wish. You can find it here. And you will have to unzip it, as we don't allow excel spreadsheets to be posted directly here.
viewtopic.php?f=4&t=16175&p=179181#p179181
