The hook na tierods maximize "misalignment" range when the tierods mount below the arms and the rack is at na miata height.
Because the lower control arms forward link taper rearward in the overhead view, the rack cannot be mounted at the miata height. This reduces the available "misalignment" range of the outer tierod (i.e. bump and droop travel without bind at the tierod). An nc tierod would reduce this further if bottom mounted.
Most likely, for a higher rack mounting, you will need to flip the tierods by drilling the taper from the top and use the nc tierod. Another option is to drill the taper to fit bolts and standard sphericals or tapered inserts you could make with no drilling of the spindle arm.
Confirm the rack width needed with a jig representing the inner tie rod joints and check for bump steer.
For a percentage of ackermann, the rack should be behind a centerline between the outer tierods.
Ford IFS
