It is currently March 28, 2024, 4:00 am
PostPosted: May 7, 2020, 10:53 am
in this video, they use 3d print metal as joint for carbon tube
https://www.youtube.com/watch?v=wXY4DU8ZqA8
it is a very easy way to build a chassis, however, metal 3d printing is too expensive for normal people
in this web, this carbon tube structures also can hold high loading, only need contact plate, Rivet & epoxy bonding
https://dragonplate.com/Square-CF-Tube-Structures
what if we use both at the same time?
for more easy to see different parts, I use different color for them
a nylon x (carbon fiber nylon 3d print material) as inner joint, its strength is nearly metal and very light
2 aluminum plate as outside joint
special cutting make the tube connect each other, so the force can transfer between the tubes directly.
PostPosted: May 16, 2020, 11:48 am
I like your concept and agree that aluminum plate is better than carbon fiber plate for the concentrated loads at joints. How about building a model of a joint?
PostPosted: May 22, 2020, 9:54 am
y u think aluminum plate are better?
