It is currently September 29, 2022, 7:47 pm
PostPosted: June 14, 2018, 4:23 pm
Here's one out in the Los Angeles area. Looks like a good base to build on. Don't know how much you're looking to spend though.
https://losangeles.craigslist.org/wst/cto/6617012647.html
PostPosted: June 15, 2018, 8:52 am
Wish I'd seen that before I blew my tax refund
PostPosted: June 17, 2018, 3:12 pm
I talked to the guy that bought my uncle's Kelmark at a local show and shine today. He hasn't done anything with it yet, but said he's going to put an Olds 455 in the back with a Riviera transaxle. He must have meant a Toronado transaxle, the Riviera was rear wheel drive. Apparently there were about 10 or so originally built like that back in the day. The guy does lots of car restorations and customer fab work, so he should be able to pull it off.
Kristian
viewtopic.php?f=35&t=7587
viewtopic.php?f=33&t=18172
PostPosted: June 18, 2018, 4:43 pm
good grief, Charlie Brown.... 455 is a torque monster. I think I'd take four plugs out before starting that one up
PostPosted: June 19, 2018, 8:27 am
There was a joke/story about a Lotus with an engine swap, don't recall the details but most any Lotus and most any engine would "fit" the story...
"They put a small-block Chevy in an original Lotus 7 chassis. Started the motor, blipped the throttle twice... And bent the frame." :mrgreen:
*EDIT* After reading that, I think just setting the Chevy down in the frame would bend it, no starting/blipping required! :rofl:
PostPosted: June 20, 2018, 10:04 am
'79-'85 were FWD; common platform with the Toro/Eldo. I don't know which transaxle they used, but at least one had the BOP bellhousing pattern since the Olds V8 was the base engine, and those were never available with any other bolt pattern.
[edit] one of the car pages says the engine was "longitudinal". It may have used the original Toro/Eldo transmission. Those were monsters with Turbo 475 guts and 12-bolt differentials.
Anyway, if a 307/350 will bolt up, so will a 455; all had the same bolt pattern.
PostPosted: June 20, 2018, 12:19 pm
Eldo 500 should be no problem..... replacing seat cushions will get expensive
PostPosted: December 26, 2018, 11:43 pm
Still looking?
Here's one on CL in Sacto, https://sacramento.craigslist.org/cto/d ... 55738.html
PostPosted: December 27, 2018, 1:53 am
The one my uncle sold is still sitting in the guy's driveway, I wonder if he'll get around to doing anything with it before the body is toast. It's been stored inside pretty much since new, now it's sitting outside in the weather. It's kind of funny that my uncle bought it as a running car with VW drivetrain, stripped it all out and never finished it, and now he's bought another VW based kit car to sruise around in. Should have just left the Kelmark alone and he would have had a cool car to drive for the past 20 years.
Kristian
PostPosted: December 27, 2018, 11:03 am
There was one on highway 57 on the south side of Sturgeon Bay, WI this summer for sale
PostPosted: December 27, 2018, 11:18 am
Still available?
They are out there if you look.
https://barnfinds.com/exclusive-kelmark-gt-1/
PostPosted: January 28, 2019, 2:54 am
You are not going to find a cheaper deal than this one unless it's been wrecked!
https://reno.craigslist.org/pts/d/reno-kelmark-gt-kit-car-body/6781273026.html
Only $800, I'm very tempted by it myself!
PostPosted: January 29, 2019, 12:43 pm
Plenty of room for your Alfa engine, and it'd save a ton of bodywork!
PostPosted: January 29, 2019, 3:09 pm
You know you want it...…. :cheers:
PostPosted: January 30, 2019, 2:23 am
I also know know I'd want to put a V6-5 Speed Fiero under it! :BH:
OP should grab this one.
Possiby changing jobs and then having to do a long commute so not the best time to get another project.
But there is a TR7 convertible that "Ran when parked" I am kind of looking at.
Only because it would be fairly good on gas and is much less of a project than all my current projects. :roll:
