Front license plate mount/location
Bodywork, finishing and painting - everything that makes your locost into an eye candy!
Moderators: dhempy, a.moore
tibimakai
Building: 442E
Post by tibimakai »
Who has a front license plate, where did you mount it and how?
Tibor
'20 Alfa Romeo Stelvio daily
Locost/442E in progress
horchoha
Building: locost super seven
Re: Front license plate mount/location
Post by horchoha »
That's a good question.
In Alberta we have no requirement for a front plate, so I've never really thought about it.
I searched the net for 7's with front plates, I found some pics but mostly with European style plates, long and narrow fastened to the lower chin of the nose.
I'm sure there are fellows here that have front plates and will post pics of them. :cheers:
KB58
Building: Midlana
Contact:
Post by KB58 »
I'm in California as well, and although they require a front plate, I never had one. It wasn't that I didn't want it there; there simply was no place for it. About the only place I can think of where it might fit is hanging from a front upper A-arm.
seattletom
Post by seattletom »
KB58 wrote: February 27, 2025, 12:11 am I'm in California as well, and although they require a front plate, I never had one.
Sometimes its better to ask for forgiveness, than ask for permission. :mrgreen:
Cheers, Tom
walt
Building: locost roadster
Post by walt »
seattletom wrote: February 27, 2025, 2:15 am
From age comes wisdom
waltj
Warren Nethercote
Post by Warren Nethercote »
In Europe they would put it on top of the nose, just above the grill. But with North American plates - Ugh!
Warren
Warren Nethercote
(double post)
Warren
KB58
Building: Midlana
Contact:
Post by KB58 »
It’s even worse when using the sleek low “catfish” nose that Kinetic sells… or sold.
mainlandboy
Post by mainlandboy »
I got busted by the cops for not having a front plate, so I mounted it under the nosecone, but folded back the bottom of the plate so that it did not hang down too low.
tibimakai
Building: 442E
Post by tibimakai »
I think that the only place I can put it, is like the above picture. Thanks for that. I may install it on the bottom grill lip to be a bit higher.
I haven't checked the rear, but I may have issues there as well, since I have a 17" wheel as a spare. Not much room to install a plate.
Tibor
SkinnyG
Building: Lethal Locost
Contact:
Post by SkinnyG »
Mine is book chassis, with a Curtis Unlimited "taller" Lotus nose. Just like the book, there is about 1-1/2" of frame hanging below the nose. I made a very simple flat bar plate mount.
My first plates were folded to fit better, but the RCMP can (and do) make a fuss about that, and I don't need the hassle, so I don't fold plates any more.
tibimakai
Building: 442E
Post by tibimakai »
Great idea. Does not interfere with the nose when you are removing it?
Tibor
mikep
Post by mikep »
There's a flat vertical area just under the grill opening on my (old) CMC nosecone. I mounted mine there on a cheap plate holder backed up with fender washers on the inside. Top is just about even with the grill opening, bottom is about 4 1/2" above the pavement - same as the sump clearance. I'll probably be twice as sorry if I bottom out but I haven't yet...
tibimakai
Building: 442E
Post by tibimakai »
I will bring the plate's height as Mikep mentioned, but I will make a holder that mounts to the bottom of the nose cone at an angle.
An H bracket for the plate and two flat bars from it to the nose.
Thanks guys.
Tibor
tibimakai
Building: 442E
Post by tibimakai »
Here it is the front one, I have just finished. Tomorrow I will work on the rear one. No space on the car, because of the spare wheel. I will install it behind the spare wheel, roughly in the middle of the wheel using the two empty holes in the spare wheel.
I will have to do something with that chassis at the bottom, I need a spoiler or something there.
Tibor
Users browsing this forum: Google [Bot] and 11 guests
