Locost 11 R1
Here is where the build logs go for non-traditional build logs. Mid-engine, three wheelers, you name it. If it's not your typical Locost it goes here.
B85
Re: Locost 11 R1
Post by B85 »
What I have learned. I can't weld .030 Alum. I have proof. :shock:
But I am moving forward a little.
Think I have worked out the door. :BH:
I will bound the door supports in after fitting or during ?
Thanks for the input Red. Trying to stay with the Alum. them until it does not work.
Doing it in glass could be cheating ? :oops:
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Re: Locost 11 R1
Post by B85 »
In 2 days I will see if it worked ?
Sikaflex 221.
Going to move over to the other side and give the 221, 2 days to fully set up. :BH:
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Re: Locost 11 R1
Post by B85 »
Just bending metal !
Will pull the clamps after 3;00 and see how it fit's :roll:
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Re: Locost 11 R1
Post by B85 »
.032 is too dam thin. :oops: That is for bending on a edge. A 180 fold.
Oh well, guess I took the "add lightness" to far ? :BH:
So I will pickup another sheet of .062 and start over. Easy ! :oops:
But I did play with the inside wall mounts. Working out the how to do's.
Oh, the bounding works but only so far. I will use it between panels but not just by itself. Welding ,rivets or something.
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Re: Locost 11 R1
Post by B85 »
Cut the .062" for the new doors.
More tomorrow.
Had to do yard work today . :ack:
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Re: Locost 11 R1
Post by B85 »
Just a start but the new left door skin in moving ahead.
The 062 is harder to shape. :ack:
But more forming to do.
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Re: Locost 11 R1
Post by B85 »
Does this look like 4 hours work ?
But I'm slow. :(
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Re: Locost 11 R1
Post by B85 »
If you will look their are some cut lines.
This will be the next step. :shock:
And maybe I will need to bake another one ?
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Re: Locost 11 R1
Post by B85 »
Took today off.
Did some TAX stuff and washed the car. ( i am scared to cut the panel )
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Re: Locost 11 R1
Post by B85 »
The Boxster is a old girl with 175,000 + but still fun. :D
So , I'm back on the door's.
Here are some photos of the process I used.
Map out the bend line. Then heat the aluminum at the bend line. ( maybe no cracks ? )
Then on to the bender. I put some tape ( x2 ) on the bend line then bend.
Then on to fitting. Easy ? :ack:
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Re: Locost 11 R1
Post by B85 »
The big black strips are marker then I heat the up until their gone.
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Re: Locost 11 R1
Post by B85 »
Major F-up.
I cut the wrong line. :BH:
Now I get to test my welding skills. :ack: And some sanding and wheeling.
Or, make a new panel. :BH:
The little panel is testing and training.
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Re: Locost 11 R1
Post by B85 »
Tacked and will weld up tomorrow ! :oops:
The bend will be almost in the middle of the flat.
American 7 5.0 T5
Lotus 15 ish?
914/H6
B85
Re: Locost 11 R1
Post by B85 »
Well. It worked but didn't work.
The weld is to hard after trying to add some radius.
But I welded it up again and re-bent it again. Need to do a little repair but should be good.
This will be painted so I can make it all good.
DON'T bend Aluminum welds or even close to it ! Ask me how I know ? LOL
American 7 5.0 T5
Lotus 15 ish?
914/H6
seattletom
Re: Locost 11 R1
Post by seattletom »
After cutting on the wrong line, wouldn't it have been easier to scrap the part and wheel up another panel?
(Don't ask me how I know :oops: )
Cheers, Tom
Users browsing this forum: Semrush [Bot] and 7 guests
