So you want to use a Duratec/MZR?
Potential donor discussions and troubleshooting, gas, diesel, electric powered builds etc..
H20ham
Building: 7 etc
Re: So you want to use a Duratec/MZR?
Post by H20ham »
Hello, I am part way into a few projects involving Duratecs. I figure the Ranger transmission is a good bet. Even on The Ranger Station I cant seem to find if there are different sizes, width mainly.
Hoping to make some progress before summer.
Cheers
Jim BC Canada
Driven5
Post by Driven5 »
On the recent alternator discussion, this thread may present some relevant info: https://www.locostusa.com/forums/viewtopic.php?t=13325
On the transmission, the Duratec Ranger was only ever offered in 2WD and with the M5OD-R1 as the manual. Because the Duratec has a different bellhousing pattern than any other Ranger transmission, and the bellhousing is integral to the transmission, there's only the one Ranger based option. I believe the M5R1 cases are all the same, such that you can even swap the closer ratio "HD" gear set from the 4.0 SOHC into the Duratec case.
a.moore
Post by a.moore »
NC Miata transmissions seem to be pretty inexpensive now. What is the benefit to the Ranger transmission?
tibimakai
Building: 442E
Post by tibimakai »
I believe there are 5 and 6 speeds available. I'm using the 6. I don't know anything about the ranger one.
Tibor
'20 Alfa Romeo Stelvio daily
Locost/442E in progress
Driven5
Post by Driven5 »
a.moore wrote: March 18, 2025, 11:52 pmNC Miata transmissions seem to be pretty inexpensive now. What is the benefit to the Ranger transmission?
The main benefit to the Ranger transmission remains its availability, and (to a lesser degree than before) price. I generally use car-part.com as my indicator of price and availability. Within 200 miles of me they show:
  • NC2/3 6-speed: 0 available. Having to look 600+ mile away for any, I'm seeing most $1500-1800+.
  • NC1 6-speed: 1 available for $1050 that just happens to be less than 50 miles away.
  • NC 5-speed: 3 available for $350 (u-pull), $750, and $1250, with the closest 135 miles away.
  • Ranger 5-speed: 50+ available, many for $200-$400, with 9 that are less than 50 miles away.
It seems that the Ranger transmissions outlast the trucks, so high supply and low demand. IMO that's still a pretty solid reason consider the Ranger transmission for a Locost.
However, if I were to start fresh on a Duratec Locost today, I'd probably lean towards the NC 5-speed. It's smaller, lighter, better shifting, cheaper, more available, plenty strong, and just as well aftermarket supported as the 6-speed. Both are better aftermarket supported than the Ranger unit, which is about as bulky as the NC 6-speed, won't mate correctly to the aftermarket Duratec oil pans, and requires building a remote shifter.
tibimakai
Building: 442E
Post by tibimakai »
I found mine on car-part as well, it was $550 w/tax.
Tibor
