962porsche wrote:
i have found out that the gear box is a little weak on the rocket 3's .
Tell us more about that--inquiring minds want to know.
962porsche wrote:
because the car is now going mid engine rear drive if the gear box needs service it's going to be a bitch to work on the thing .
I wouldn't try working on the gearbox of any single-case bike engine while it's still in the frame--pull the engine and do it on the bench. If the Honda has a separate transmission case, a la some Harleys and Royal Endfields, that's a different story, but the Rocket III (and Hayabusa and KZ1200 and every other current production bike I know of) has the trans in the engine case.
962porsche wrote:
i don't even know if the rocket motor is going to fit ?
right now i only have a half inch between the fire wall and the front of the motor .
I just now slapped a tape measure on mine--it's 22" long; maybe that'll help. I measured it in the bike and don't know if the drive shaft sticks out the back of the engine. Out of curiosity, how long is the Goldwing powerplant?
962porsche wrote:
this hole chassis and cage is all designed and built for the honda motor and the mx-5 front and rear suspension with the mx-5 diff ...i don't think there is a big deferents between the two motors power wise to justify the cost of the redesign .
You have a bunch of good reasons to stick with the Goldwing, no matter how good the Triumph Rocket III motor might be (or what we, your fellow Locosters, think of it). So I'd suggest you quote your customer a redesign fee, advise him the power difference may not justify
the cost of redesign, and let him decide; he'll probably agree with you.
Locost builder and adventurer, and owner/operator of
http://www.kineticvehicles.com
