There's lots of good information there, but not much talk of cost. Since most of us here like to focus on bang for the buck, I thought it would be nice to focus on an inexpensive homebrew setup with cheap Ebay or junkyard parts. Sure anyone can cobble something together that makes boost and melts pistons, but I'd like to reach a consensus (on an internet forum I realize it would be a first) on a cheap, functioning, reliable system.
Since we are doing this on the cheap I think we should first agree on what compromises are worth making.
Would everyone agree that maximum power and performance should not be a goal, but rather something realistic for an inexpensive system.
Fuel management is always a subject of debate, though I think everyone will agree a standalone system that controls fuel, spark, and boost levels is ideal. My question is, "but is it a requirement." It can be had rather cheaply for my Miata mill at $700 for a MS PNP, but can you get by without it.
I remember back ages ago when I drove Neons and read the Neon boards. Lots of people used rising rate fuel pressure regulators and larger injectors etc. to get more fuel. They had problems getting the car to idle, and spent a lot of time doing engine swaps.
How cheap can you go without being reckless to a point it becomes counterproductive and you find yourself spending more money because you are replacing engines on a regular basis?
Here are some cheapo Ebay parts I've had my eye on. If anyone can offer informed opinions on them I would appreciate it. Got any other suggestions for cheap, low-buck setups? Please share them!
Prices below include shipping.
Cheap 1.8 Miata manifold:($135)
Full Stainless Turbo Manifold
Brand New Turbo Manifold for Miata 1.8L NA Convert to Turbo Setup
T25/T28 Turbo Flange
This turbo manifold will fit 1.8L (DO NOT FIT 1.6L)
SUS304 STAINLESS STEEL
MANDREL BENT TUBES - NOT CRUSH BENT!
EACH MANIFOLD PORTED AND POLISHED FOR THE MOST POWER
Cheap T25 Turbo: ($230)
JDM'S T25/T28 Turbocharger!!
Turbine Turbocharger
Oil cooled and water cooled
Compressor Specs :
1.70" Compressor Inlet
1.685" or 42.81mm inducer
2.362" or 60.00mm Major
Compressor .80 A.R.
M24 T2 Compressor Housing
Turbine Specs :
1.850" Exducer
Turbine .86 A.R.
2.090" or 53.10mm Major
1.820" or 46.25mm Minor
Exhaust Outlet Flange with 5 bolt design
Comes with internal wastegate set around 7psi.
Suggested for 1.6L to 2.0L engine up to 100-275HP
[/quote]
