Know what you mean about the $10.00 bid situation. As hard as it is for me to chuck stuff
Ron
rust_bucket wrote: but my only word of advice is give yourself more room than you think you'll need.
rust_bucket wrote:I wasn't about to shorten the drive shaft myself. I can deal with a weld failure on a pick-up point or even an A arm, but on a hunk of steel whizzing around at 5,000 rpm, 3 inches from my hip!? No. Not on your life. So I dropped my drive shaft off at the local shop that did my 390 to 9-inch conversion for the Ford a few years ago. I got the usual response for a Miata unit: "Sorry dude, it's not rebuild-able, the forward end is crimped on." I knew if I went in swinging with big demands and a short timetable he'd tell me to hit the road, so I took the patronizing approach: "Well, I know others have done it and if anybody in the county can, it you. Put it on the back of your pile and stew on it for a while. See what you can come up with, I'm not in a big hurry." - Which wasn't exactly true. I wanted it done ASAP, but better to see if a professional can salvage what's there than have to pay for a brand $panking new unit.
He finally agreed and said he'd cut it apart to see how it was put together. After about 3 weeks of waiting he agreed he could do it. He's going to completely disassemble it and machine off the crimped tube on the forward end. He insists that the U joints need to be replaced too and won't accept the liability of letting one of "his" drive shafts out the door with joints that bad so I agreed to all of the above. I'm afraid the initial $55 quote is going to triple -or more.
- - - Maybe I should have just had a new one made...
rust_bucket wrote:I picked up my rebuilt drive shaft yesterday. We played a little game of cat-and-mouse before agreeing to $175. I think that's fair for the science experiment it turned into. - Makes me wonder what a new one would have run... $300 or so I'd guess. He said it should be bullet proof and stronger than the one that came out. - I mentioned that I was putting it in a car 1/2 the weight of a miata and he just chuckled saying "Well, keep it lubed up and it will last forever."
I installed the thing and it fit PERFECTLY! Yahoo!
Bought the crush washers and installed
Replaced the missing nuts for the rear half shafts
Buttoned up some more of the wiring harness so it won't flap in the wind on Saturday (hint hint)
bolted in the battery
charged the battery
put the wheels back on and torqued them to spec
checked the Ebrake - works perfectly
re-installed the gas tank
re-routed the rear wiring harness through the tunnel so it won't get wrapped up in the newly installed drive shaft.
Did a thumb-in-the-air alignment
Torqued the steering wheel on
tightened up the steering column
Now all I need is some gear oil, brake fluid and two stupid stinkin AN3 sleeves and nuts for the rear. They're supposed to be here by 2:30 today...
I'm guessing I'll spend a few more hours wrapping up the "oh yeah, I have to take care of that before I can drive it..." type stuff I can't think of right now, but I'd say Saturday is highly probable.
Here's hoping for no Cops in the neighborhood this weekend.
